![]() | Home > Td5 > Thinking about fitting a large Intercooler to my TD5 |
I don't think you need a new remap. The ECU is measuring the Manifold presure and temperature and also the airflow. So it knows how much air is going in. When you fit a larger intercooler the air will be cooler so the ecu knows that there is more air going in so it knows it can inject more fuel.
You can get more power out off the Td5 engine but that is another story. I use a standard intercooler and according to my Nanocom my inlet temp doesn't get higher then 55 deg C that is 328 Kelvin If you would be able to cool it down to 30 C which is very optimistic I think. you get 7% more air in your cylinders so you could have 10 HP more. ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
It'll be fine. Whack it on
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
I would have Gary give it a tweak will be smoother and give better torque
Their black intercoolers are superb 2008 110 2.4 XS Utility (Hagrid) 2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2965 ![]() ![]() |
Is there any point fitting an uprated intercooler to a standard TD5?
Not unless you tow or use it in hotter ambient temperatures other than the UK. If you go through life with your head in the sand....all people will see is an ar5e!!
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
If you fit a larger intercooler, you will need a larger turbo to see the effects at lower rpm.
There's a slight drop in the performance at about 1100 rpm, as you are trying to fill a larger space with air. If you are not intending on changing the turbo, you can shorten the waste gate rod. I've done each of the mod piece by piece so that i know the change effects. stock map change to 1.222 t-box write a map Turbo waste gate shorten remap again change intercooler remap again changed turbo to vnt remap again i didn't push the engine as it's aging and i'm not for milking all the power gains, i'm after an easy drive and better acceleration. it happened over 5 to 7 yrs as much as my pockets could afford. The defender has migrated, leaving the owner behind. |
