Home > Technical > swivel hubs |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1766 |
Drivers Side is so dry I'd be worried that there's not grease in it!!!
29th Aug 2016 10:31pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
For the sake of a mornings work and a few quid I would strip both sides down, new seals and a new one shot of grease in each. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
29th Aug 2016 10:41pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
As miker said
It seems too dry the other side. They all weep slightly.Think you should sort it sooner than later |
30th Aug 2016 6:28am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2250 |
Personally, I don't think there's anything wrong with it. Most have a swivel that seeps a little bit. If it bothers you, clean it up and do it again next year.
30th Aug 2016 7:46am |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 |
Mine are the same but the other way round, drivers side is damp, passenger side dry as..
I think as long as it's not pouring out just leave well alone. A quick wipe at MOT time |
30th Aug 2016 10:18am |
srod Member Since: 20 Mar 2015 Location: Argyll Posts: 190 |
So a range of opinions thanks to all for the advice.
Regarding the dry side - as I understand it the grease in the swivels on an '03 TD5 can't be topped up, but will require stripping cleaning out the old and topping up with the correct amount of new grease... If a complete strip and rebuild is needed, then given the time involved maybe it's better to leave it until the swivel itself or something else in that region (bearings? brake discs?) needs replacing and do it all in a oner? Seems like more than a mornings work (for a first time attempt), although happy to be convinced otherwise! |
30th Aug 2016 2:49pm |
The tracta seals are easy to do;
Wheel off Disconect steering arm Remove brake calliper and hang out of way (removing top bracket from hub) Remove bolts holding hub assy to axle casing Slide it off including drive shaft Flip on front Remove retaining bolts on plate Remove seal Repeat process backwards to reinstall (new calliper bolts to be fitted) 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
30th Aug 2016 3:18pm |
