![]() | Home > Td5 > Parts to have ready at home |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 716 ![]() ![]() ![]() |
Worth adding an oil and air filter, sump plug washers plus lubricants if you find it difficult to get those also.
Thermostat, wheel bearing and one of those easily breakable screws on the coolant hose would be handy. We run a few 2013 Defenders in Ghana, the main dealer doesn't keep basics such as brake pads in stock ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
A viscous fan removal tool wouldnt go a miss
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Injector harness and cover gasket.
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Fuel pressure regulator (or seal kit for same). 2005 Td5 90 XS
Steve |
DuncanS Member Since: 06 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Headlight stalks, or put relays in to bypass the current in them! North Cumbria Search and Rescue - Team Leader
stickyyates Member Since: 03 Sep 2015 Location: notts Posts: 11 ![]() ![]() |
Spare defender
