Home > Technical > Priming procedure following fuel tank removal |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
I'd just see if it starts, but i'll bet you a finger of fudge it will
27th Jan 2011 10:12pm |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
I'm also fairly sure it will start as there will be fuel in the lines/filter but am I likely to get problems with airlocks etc?
27th Jan 2011 10:25pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
When it starts it will pull them through NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
27th Jan 2011 10:32pm |
Thanks guys will give it a go in the morning
27th Jan 2011 10:36pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Easiest way to bleed a tdci or any diesel engine for that matter is to pressure the tank slightly with a airline with the bleed nipple open and it will push the diesel through the lines.
Pete. |
27th Jan 2011 10:47pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Dont think they have bleed nipples 130's have feeling's as well you know
27th Jan 2011 10:58pm |
Just for the record, started no problems and no need for priming
28th Jan 2011 9:57pm |
You may well be right there! In that case disconnect the pipe that you would if you was bleeding it how land rover intended. I was just giving general instructions that work on any diesel engine that needs bleeding. Pete. |
31st Jan 2011 9:26pm |
