Home > In Car Electronics > Dab Antenna |
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 |
I purchased from Dabonwheels and roof mounted. It's a bee sting type and I have to unscrew the mast occasionally to get under barriers, but no big deal. I live central belt of Scotland and signal is good.
26th Aug 2016 6:47pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
I have the small Halfords magmount one which holds firmly on the box section of a Brownchurch roof rack (Overhanging trees excepted). Reception has been good everywhere from North London out to Essex, Oxfordshire and down to West Wales and Devon. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
26th Aug 2016 7:32pm |
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 |
Dabonwheels roof mount stinger on mine too
26th Aug 2016 10:03pm |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 |
This is mine I had fitted in the UK. They said the roof would have been a better location but as I had a roof rack that wasn't possible. DAB seemed to work fine in the UK but here in France we have no DAB outside of the largest cities. It works fine as an FM aerial however I rarely use it. I always use Apple CarPlay and Tunein radio to get UK stations in my cars here in southern France. I think it looks pretty good though.
Click image to enlarge |
26th Aug 2016 10:40pm |
Defender2014 Member Since: 25 Aug 2014 Location: Buckinghamshire Posts: 65 |
Small mag mount on roof rack and then fed cable in underneath the rear passage door seal. Defender Puma 110XS SW
Kawasaki ZX9R El Suzuki RGV250M Honda CB250N Super Dream |
27th Aug 2016 8:42am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4194 |
Has anyone tried the adapters that let the standard aerial double up as a DAB one? 2007 110 TDCi Station Wagon XS
27th Aug 2016 9:44am |
Lew-M Member Since: 04 Apr 2016 Location: North West Posts: 95 |
I used the cheap ebay window mount type, around 12 quid I seem to remember. I mounted it in the center of the window at the bottom where the dash joins, using the dash mount as an earthing point. Barely noticeable and works very well so far.
Lew |
27th Aug 2016 9:52am |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
I've bought a Aerial converter for the std antenna... I'll advise on reception when I fit it next week hopefully
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
27th Aug 2016 5:54pm |
A review would be great, because if it's ok that's what I'll go with. 2007 110 TDCi Station Wagon XS
27th Aug 2016 7:24pm |
New Stereo fitted CDE136BT with a cheap DAB on wheels FM Ariel converter... DAB works quiet well...Would happily recommend it... I'm northern/central belt Scotland... So if it works here... Should work anyway.
31st Aug 2016 8:02pm |
Great, I think I'll give a DAB adapter a try too. Could you let us know which one it was you bought from DAB on wheels? 2007 110 TDCi Station Wagon XS
31st Aug 2016 10:28pm |
http://www.dabonwheels.co.uk/Kinetic_DAA-7...itter.html
There you go Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
1st Sep 2016 6:39am |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 352 |
Has anybody tried one of these? Mulling over mounting on an Alpine window so that it doesn't get impacted by the heated screen elements. Keith
8th Feb 2017 11:04am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 735 |
Last week i fitted a window mounted Alpine KAE-242DA-R DAB aerial seemed to work ok but only lasted a week, a Pheasant flying at 55 Mph cracked the screen...
Just been considering a "splitter" to use the std aerial... |
8th Feb 2017 11:16am |
