Home > Maintenance & Modifications > Mud trap - inside wheel arch lip
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
Morning all,
My 110 has 285/75/16's on mods plus the extended wheel arches. The problem I always find is that the inside wheel arch panel lip is exposed to the elements and is a sand/stone/mud trap and was curious if anyone had done something about that?
I was thinking of external Window Door Excluder Seal Strip to fit under the lip and is a low cost interim solution and am open to any other ideas for you lot Bow down
http://www.ebay.co.uk/itm/D-black-Foam-Dra...wgxzFIF-WQ
Thanks
Steve
Post #558198 23rd Aug 2016 6:48am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
How about some of this to "clip" over the lip? I used this on my Freelander 2 to replace the original stuff on the wheel arches which had corroded badly, I squirted a load of Dinitrol into the cavity in the seal first to help reduce any further corrosion of the metal lip.
http://www.ebay.co.uk/itm/111912389564?_tr...EBIDX%3AIT
Post #558204 23rd Aug 2016 7:03am
Hairysteve
Thanks Clive, that looks like a much better idea Thumbs Up
I will fit this after the 110 has had its Dinitrol treatment with Zagato which is in a few weeks and let you all see the photo results.
Got to love this forum Bow down
Post #558212 23rd Aug 2016 7:26am
