![]() | Home > In Car Electronics > Electric window switches |
I stuck holding the button down until the window is open
![]() Click image to enlarge Last edited by dorsetsmith on 22nd Aug 2016 10:05pm. Edited 1 time in total |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
Probably easiest to use another manufacturers switches and electronics and hardwire / custom integrate it using OE LR switches.
I'm not aware of a manufacturer that does one touch electric windows though, is there some? Breakers may have the gubbins around, cheaper. |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3820 ![]() ![]() |
Not something I miss from previous cars. I can press a button for a fee seconds, now cruise however would be nice.
I do miss not having electric rear windows as the kids sometimes leave them down a little. I jump in to drive to work and hear the wind coming through.... Some convertible cars we have owned have the one touch for all the windows, so maybe you could use the switch, my wife's Mini currently has that, one rocker switch and all windows go up or down. |
sailawaybrad Member Since: 14 May 2016 Location: Nr Exeter Posts: 43 ![]() ![]() ![]() |
Could I install a switch that allows one switch to operate both windows do you think?
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
My Peugeot drivers window is one touch and I always forget that in the Defender I have to hold the button until it's fully open.
Perfectly possible and not too difficult or time consuming to add cruise control. It's not adaptive CC though sadly! |
On my Defender I installed the DEI 535T module (one module for two windows):
https://www.amazon.com/Directed-Electronic...B00H4N1Y2O Installation Manual DEI535T: http://pdf.ampire.de/directed/535T_englisch.pdf On my mate Defender I installed this one but you need 2 modules (one module for one window): http://bluewireautomotive.com/products/one...dow-module Both solution work very well! (but I prefer the DEI535T, more "professional/OM) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License Last edited by dgardel on 24th Aug 2016 10:04pm. Edited 1 time in total |
cheeper solution
http://www.ebay.com/itm/AutoLoc-One-Touch-...mp;vxp=mtr With installation manual: http://static.summitracing.com/global/imag...wc1000.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
