Home > Td5 > Td5 Webasto
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Td5 Webasto
Any have a picture of exactly where the dosing pump is supposed to be mounted? Looks like inside the frame rail on the right side??? I have a horrific official Webasto install guide, but the pictures are very poor and the English translation from German is worse than most Chinese instructions.
Also.....anyone have a pic of the one way valve installed on the main lines? (18mm hoses) hoping to capitalize on someone else's elegant solution before chopping up my 18mm hose.
Thanks
Patrick
Post #557659 21st Aug 2016 12:27pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
PM me if you want a copy of the install manual. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #557686 21st Aug 2016 3:12pm
HansT
Sweden 2004 Defender 110 Td5 SW Belize Green
In a protected plastic box fitted to rh side member close to the fuel filler pipe from where I also pick up the fuel to the pump.
I have some more pictures if you need.
Regards/Hans
Post #557888 21st Aug 2016 11:08pm
Justtellme
Thanks! I have the manual and that pic, but I'm having trouble figuring out where that exactly is on the vehicle! I was hoping to see a pic of one on a vehicle with a bit more field of view.
Patrick
Post #558084 22nd Aug 2016 7:56pm
Justtellme
Regards/Hans
Very nice!
Post #558085 22nd Aug 2016 7:57pm
4RF RDS
Its just on the inside frame rail passenger side (LHD) opposite this spot in between the frame and prop shaft. Hope this helps some? Mine was dealer installed 16 years ago.
1967 MGB GT
Post #558123 22nd Aug 2016 9:57pm
Justtellme
perfect!
Thanks...that is exactly what I was looking for
Patrick
Post #558303 23rd Aug 2016 2:34pm
4RF RDS
No problemmo. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #558365 23rd Aug 2016 6:59pm
