Home > In Car Electronics > Elictric window switch
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Hi All.
TD5/06. Her Ladyship who is disabled has asked if I can fix the electric window on her side, to operate without the ignition on. Her other request was to fit a horn with a switch for panic use, that seems to not be a problem , horn,relay, switch, from halfrauds.
So can any one advise re the window switch, will it affect the central locking ??.
Her Ladyship is a Tetraplegic , with the disabled stickers on the truck she admitted she feels vulnerable when left on her own.
Edward
Post #557566 20th Aug 2016 9:28pm
You sound quite competent regarding the wiring and I wouldn't worry about the central locking. As far as I am aware the two aren't linked.
It would be unlocked anyway wouldn't it, I'm just assuming she would want to use it unlocked but ignition off?
If so I can see any issues at all.
Post #557570 20th Aug 2016 9:40pm
rallysteve
Do you have heated seats? If not remove the 'ignition relay' from the fuse box in front of the gear lever and put a wire link between the two switched terminals (use wiring capable of 20A+). This will make the window circuit live permanently and is easily removed.
Post #557609 21st Aug 2016 6:41am
dorsetsmith
may help with your mod Whistle
Post #557634 21st Aug 2016 9:18am
EWS
Rally Steve- yes we have heated seats,and thanks for the suggestion re wiring
Dorset- Thanks for the wiring diagram
Just completed a mod for her. Her own heater controls ,2 speed switch and a bowden cable (bonnet pull thingy) mod ,( to work the heater flap) attached to the front of the cubby box . I am allowed the choice of screen or floor airflow.
Post #557862 21st Aug 2016 9:07pm
