![]() | Home > Td5 > 2002 onwards rear door card replacement? |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315 ![]() ![]() ![]() |
Does anyone know of an alternative to the 2002 facelift model rear door card?
The existing plastic door card isn't useful for mounting shelves or other equipment on but does cover the wiper motor and central locking actuator. I'm thinking metal plate, does anyone produce something commercially or do I need to get my tape measure out? Sandy |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 959 ![]() ![]() ![]() |
I decided to just get some 3/16ths aluminum and cut to fit. Wrapped it in vinyl. Really strenghtened the rrear door cost $50 in total (that's like £20) and about an hour of work. You can attach aynthing to it.
![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge . 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2946 ![]() ![]() |
Looks good.
Is that a 300tdi though? The O/P has a TD5 and it doesn't have the plastic covers for the wiper motor/lock etc. Although l guess you could fit some from a earlier model? |
Thanks. Its a Td5 and the plastic bits are easily sourced. Had the alu cut to match the door card then got it home and used a jigsaw to cut the rest. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
kzycnn Member Since: 24 Apr 2009 Location: Northumberland Posts: 277 ![]() ![]() ![]() |
I fitted one of these https://www.devon4x4.com/d44-defender-rear-door-protector.html over the top of the standard door card (mine is a post '02 defender TD5, not a TDCI but it's the essentially the same door anyway). I then fitted a drop down shelf for cooking etc to this. Works very well.
Tony |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 ![]() ![]() ![]() |
Really nice job ![]() |
