Home > Technical > Difficulty Replacing Number Plate Lamp |
Chocolate Member Since: 18 May 2012 Location: Berkshire Posts: 153 |
Hi David
You have to remove the speaker panels, or you can get to the nuts by just removing the speaker. I did this recently when replacing mine to LED. You can just about see the holes with the speaker removed. Bit of a faff but not too bad.. Wayne. 110XS CSW TD5. |
18th Aug 2016 11:01pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20359 |
You'll need to access the nuts from the inside, remove the speaker inside in the panel and locate the nut(s).
Probably quite awkward but easily possible, if really awkward remove plastic speaker panel too. The nut(s) won't be lost anywhere they will be present just behind there at the bottom. Simply hold it one side and tighten the other. Don't over tighten either. |
18th Aug 2016 11:04pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Getting to the nuts has been covered, Land Rover fitted very few captive nuts to the Defender from what I've found.
For the wireing it looks like the origional wires are used from what I can see in the picture. There may be a screw in the " bullet" conectors or it may be a solder job. Cheers, Kyle. |
19th Aug 2016 3:54am |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 |
David, as above posts you need to access from behind the light.
I changed mine last year with an LED unit from MUD. They have instructions on line on the fitting of this unit. http://www.mudstuff.co.uk/led-number-license-plate-lamp.html just click fitting instructions Hope this can help you sort it out mate, it was quite an easy job, as I was able to do it Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
19th Aug 2016 5:18am |
Lotus_esprit_s1 Member Since: 01 Oct 2014 Location: Uk Posts: 201 |
You need to cut the wires off you original unit. You then strip approx 10mm of insulation off each one. Remove each "jet engine" (bullet) from the lamp. Push the wire through the back of each bullet so that the bare wire is sticking though the hole. Fold the bare wire back over the bullet then push the bullet back in the lamp socket to make the connection.
19th Aug 2016 5:53am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
It looks to me like you've got the wrong one, I'm pretty sure the newer type comes with the wires attached, terminating in a two way connector which sits inside the rear cover or speaker.
As already mentioned, the nuts are not captive, they're accessed from inside behind the cover/speaker. |
19th Aug 2016 9:56am |
Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 313 |
Seconded, go LED https://www.firstfour.co.uk/defender-wipac...-lamp.html Sandy |
19th Aug 2016 10:18am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
You've got an earlier bullet-type lamp as a replacement, rather than the plug-and-socket type.
If you can solder or know someone who can you can use the leads from your old broken one to convert your replacement. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
19th Aug 2016 10:37am |
If you go LED to swap definitely go for the one in the FF link above. One before I had was useless.
The Wipca one in the link I have now and is faultless |
19th Aug 2016 11:17am |
Birdy Member Since: 07 Oct 2011 Location: Côte d'Azur Posts: 865 |
I can understand the OP replacing his smashed number plate light light with an LED one, possibly cheaper than one from the dealer.
But why do others replace perfectly good ones? And flashers, side repeaters etc.? Not trolling, I've upgraded the headlamp bulbs on my own truck, but need to be explained the advantage of LED'ing the rest. Peter |
19th Aug 2016 5:07pm |
Seriously? In the first three years of ownership I replaced three bulbs and four complete lamp units (rear/brake and indicators) due to the outstanding quality of these items (water ingress, melted bulb holder, corroded bulb connectors etc. etc.). I then replaced all indicators, rear/brake and dim headlights by sealed led units (RDX), now 5 years ago - never had a problem since... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
19th Aug 2016 6:52pm |
To be fair my mudstuff lamp is running fine after a year and provides a good light. I'm happy, it matches the rest of the LED lamps on my 90 Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
19th Aug 2016 7:46pm |
Is that Wipac? There is two types with different LED styles.
Wipac's I have now and is excellent, the other Le Perei I think it is or something was crap. SMD vs Regular again, IMO SMD LED wins every time. |
19th Aug 2016 7:51pm |
Not sure if it is wipac, no branding on cover, all the same looks good and no problems after a year.
How do the LED's differ, mine gives an even spread of light across the number plate. Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
19th Aug 2016 8:07pm |
