Home > Puma (Tdci) > Interior heater not going back to cool... |
Goeie morgen, niks verkeerd met 30 graden natuurlijk. Binnen een paar maanden (of eerder) vragen we daar weer naar.
Now, I think that possibly your solution might be the same as the one in the posts toward the end of below thread. It could be that same heater valve, and maybe as easy to correct as Gren did. Take a look. Eric http://www.defender2.net/forum/topic47480....ontrol+hot You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
17th Aug 2016 4:34am |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 |
The heater is controlled by a simple water valve in the engine compartment.
In order to find out if it is the valve or the cable thatīs at fault, you will need to disconnect the two. Under the bonnet, left hand side (on a LHD model), high up near the bulkhead. Once disconnected, you should be able to move the valve itself to itīs fully closed position, and put an end to your plight! By the way, the AC is probably working, but the heater is too powerful to overcome it. So once you cut off the heat, the cool air of the AC will return. Good luck! 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
17th Aug 2016 5:08am |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
There is a little flap thing on the heater in the engine bay, this is sometimes not closed properly via the temperature knob. Just give it a push down to close it all the way and you should find the AC working properly again. In this situation, the AC still works, it's just being overpowered by the heater.
I hope this helps. |
17th Aug 2016 6:36am |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 |
Thank you all.
Course was indeed at the engine bay heater valve side. The clip holding the cable was lose. Heating, full-open was easy by pushing the complete cable, but closing not as there was no resistance by the clip. I am able to drive home safe (cool) now without to much hassle 😊 |
17th Aug 2016 10:14am |
As far as I know - at least in my Defender - the heater matrix and valve in a LHD model sits at the right hand side (that is standing behind the vehicle and looking forward. (On the left side there is de brake servo). Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
17th Aug 2016 7:10pm |
Thanks VT. It depends how you look at it, doesnīt it? 1998 Tdi 90 SW,
17th Aug 2016 7:38pm |
Indeed. I am not an Englishman, but as the English say, there is only one right side and that is the left side... Cheers, Vincent
17th Aug 2016 7:42pm |
Dear VT, lets sort this out properly, shall we? if you are right (er, I mean correct) and the heater valve - quote "in a LHD model sits at the right hand side (that is standing behind the vehicle and looking forward." - Iīll buy you a crate of beer of your choice. If, however, it is on the left hand side (also viewing from behind) above the brake servo, and not as you describe, on the same (right hand) side as the heater matrix, then Iīd like 12 bottles of your best local brew. Are you up for it? 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
18th Aug 2016 4:46pm |
As I said before - and I also explicitely mentioned my LHD model - under my bonnet the brake servo sits on the left (what is very logical, because it also happens I sit on the left, otherwise you have to be very gymnastic to touch the brakes), and the heater on the right. I just took a picture, standing before the bonnet looking aft, so you have to correct for that standing at the rear looking forward (and in the latter position it is not possible to take a picture with open bonnet ). Click image to enlarge So... cheers! Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
18th Aug 2016 5:09pm |
Dammit VT you got me there! You did say "at least on my Defender" and you were right, as its a TDi.
Well done.......well almost. As we are in the TDCi section, and the OP was asking for information applicable to his 2012 2.2....ok, ok Iīm buying! Just for the record, hereīs one they did recently.... Click image to enlarge 1998 Tdi 90 SW, 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MTīs, Recaro CSīs, anorak, wellingtons |
18th Aug 2016 5:25pm |
Haha, there you have a point too! I only looked at the op's country flag, and thus supposed he was driving a LHD model. However I did not realise or know that there is such a difference between 300 Tdi and the later models - concerning heater location and layout of course. Thought because of the location of the brake servo the heater on the later models, even LHD, couln't be on the left.
So I guess we're sort of quitte - must have a beer together sometime and talk Land Rover ... Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
18th Aug 2016 5:34pm |
1998 Tdi 90 SW,
19th Aug 2016 4:59am |
