Home > Maintenance & Modifications > LED Headlamp - are these suitable?
justinp
Hi Chaps,
Do these headlamps look suitable for a 2012 Defender? I'm told they have the relevant approvals for the MOT so they may be a cheap upgrade to LED headlights.
Many thanks - Justin
Post #556422 16th Aug 2016 12:09pm
Cupboard
Everything that it says reads fine, just up to you whether you think it's too good to be true or not.
Passing an MOT doesn't necessarily mean it's legal, but they say they have European Type Approval and you can see the little mark on the lens. If you assume that the lumen rating is for a pair (which it must be because that would be mad for one) and if you assume that those are theoretical LED lumens as opposed to actual output lumens (which you'd expect as they usually use the highest rated if they only show one rating) then they're slightly less than the Noldens.
IP rating of 67 is for temporary immersion which is fine, but it doesn't give any water jet rating (IP66 or IP69k for instance) so you don't know how well they'd do for pressure washing. FWIW the Noldens only give a jet rating (IP69k) but don't give an immersion rating so you can't hold that against them too much Whistle TBH anything's going to be better than the standard units in water resistance.
What setup do you have at the moment? You can gain huge improvements over the factory candles by upgrading the wiring and the headlight units themselves.
Post #556428 16th Aug 2016 12:44pm
Stacey007
^ What sort of price are these.
I was looking at similar and yes they are not expensive but surely an increase in the std candles and also look better ?
Post #556437 16th Aug 2016 1:17pm
There's an interesting video on mobilecentres FB page that reviews about 12 different led headlamp units ... The results may surprise a lot of owners Whistle
Post #556440 16th Aug 2016 1:29pm
You had to didn't you Rolling with laughter
Post #556442 16th Aug 2016 1:31pm
Whistle
Post #556444 16th Aug 2016 1:32pm
ericvv
Any way to see that movie if you are not a FB user?
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #556445 16th Aug 2016 1:44pm
Try this ....
Post #556449 16th Aug 2016 1:59pm
ericvv
How interesting. Some real surprises in there. Laughing
Will be interesting to find the individual tests mentioned in that movie for each of those lights. Speaker, Nolden and Trucklite in the first place. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
Post #556512 16th Aug 2016 6:37pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I love how Americans can fill 12minutes and 45seconds with what most could say in 2minutes. They really love their own voices! 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #556553 16th Aug 2016 9:37pm
H3nry
Interesting thing to see Nolden's report.
Post #556589 17th Aug 2016 3:24am
