Home > Technical > Modifications to spare wheel cover |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4721 |
Got an inexpensive spare wheel cover for the bonnet mounted spare on the LR 88. To stop it billowing up by air forced under it while driving I got the "technical department" i.e. the wife to put some vent holes in it.
Here's the before treatment Here's the original article Click image to enlarge Here's the kit used Click image to enlarge Here's the finished article Click image to enlarge Turned out really well. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
12th Aug 2016 6:12pm |
OEM ones normally have one of those at the lowest point to let water out too. If you go through life with your head in the sand....all people will see is an ar5e!!
12th Aug 2016 7:03pm |
Enid_Puceflange Member Since: 25 Oct 2014 Location: edinburgh Posts: 1173 |
Did it work then?? My confidence has been writing cheques that my abilities can't cash for years.
14th Aug 2016 9:30pm |
Got the engineering dept. to add two more holes making a total of four but it still billows up. So no success. 1982 88" 2.25 diesel
15th Aug 2016 3:24pm |
A bit of cord and use the new holes to tie the cover down to the wheel Ray
15th Aug 2016 3:28pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 629 |
Is what I did on my 2A and it does work. 1995 Defender 110 CSW
1971 SIIA Lightweight |
15th Aug 2016 4:12pm |
15th Aug 2016 4:52pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17467 |
Get a circular board approx 24" in diameter and bond it inside the cover.
15th Aug 2016 6:42pm |
