Home > Technical > Wheel speed sensor faulty?
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Hi, running a routine diagnostic test yesterday and noticed the right rear wheel not showing any speed. All the other three as normal. No codes showing or problems with ABS or TC.
I am changing the springs on Monday so when the wheel is off I'll have a good look for chaffed wires etc but is there any test that can be carried out on it? How does it fit? Is it a push fit. Hope it's not Censored as they seem to be mighty expensive.. As it's not showing any faults or causing any problems should I just ignore it?
Post #555766 13th Aug 2016 4:08pm
Pinky
No one got any ideas?
Post #556674 17th Aug 2016 1:06pm
If you have no error codes showing I would leave it alone.
Post #556679 17th Aug 2016 1:13pm
