![]() | Home > Puma (Tdci) > Door seals holding water |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 391 ![]() ![]() ![]() |
Hi. Yes my 90xs does this. I just drain them occasionally by opening the doors
I guess once the door seals wear out they won't hold water any more? ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5018 ![]() ![]() |
When the door is shut the hollow seals compress, the air is let out by little holes further up the seals. This is where water can enter. If it drains as per your pic it shouldn't,t be a problem.
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
They all do it and always will
![]() Doesn't seem to have any ill effect though as it just fills up a rubber tube. Just remember to open the doors after you wash it and let it trickle out. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
dashed Member Since: 12 Jan 2015 Location: Manchester Posts: 29 ![]() ![]() ![]() |
THanks - will stop worrying!
xtr2turbo Member Since: 30 Apr 2016 Location: Hertfordshire Posts: 71 ![]() ![]() ![]() |
I noticed the same. My concern is what happens when it freezes
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
My 110 Puma was outside 24/7 all year round and in some very cold freezing weather, never had a problem with door seals
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
Mines the same, just glad it drains outside and not inside
![]() I have one of the dry Defenders Cheers Simon I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
Nothing at all, it just expands the rubber a bit and doesn't drain out until it has frozen ![]() Self confessed mileage hunter ![]() |
Freezing water trapped inside the seals can expand to such a degree that it can split a Defender in two - seriously ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
