![]() | Home > In Car Electronics > OEM dash switches - where? |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
You'd have to make one
Just pick your switch type (fog or heated window) and then replace the cap with the blank |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 ![]() ![]() ![]() |
I think a few people have had issues fitting an electric ariel due to the lack of space. Might be worth searching the forum for advice.
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
Sounds to me like a complicated solution to a simple problem, as driver9 ^ says ^, space under the wing is very limited for fitting an electric aerial so why not fit one of those stubby flexible type aerials instead ?
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
Pop a "shark fin" aerial on the roof... Not much to snag, just a slight PITA to fit... ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
On my Defender I have a vintage but bought new "Autovox SA-86" stainless steel electrical aerial manual so I can decide how extend or close. It fit perfectly.
![]() Click image to enlarge or this types are also good ![]() RetroSound PA02 Flexible Mount Electric Aerial ![]() RetroSound PA03 Compact Electric Aerial Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Scrawf Member Since: 24 Jul 2016 Location: Matlock Posts: 25 ![]() ![]() ![]() |
Many thanks!
