Home > Puma (Tdci) > Defender 110 Station Wagon A-pillar roof bolt loose
Stickman
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
Hi, I thought that I would share my latest Land Rover antics!
We are about to take our Land Rover on a trip to Spain and Portugal and I have been working through a list of preparation jobs. We are taking a roof tent and I have built a full length aluminium roof rack to carry it along with a cantilevered extension to carry 4 bikes! When mounting the roof rack I noticed that the front section of the roof gutter on the drivers side, where it meet the A-pillar was quite mobile, such that when you pushed / pulled the corner of the roof rack you could feel / see the gutter moving. I wasn't too happy with this as I was concerned that over time the metal might fatigue if subjected to cyclic loading. I then set about removing the front section of headlining, which is possible without having to remove the centre section. I made a tool for getting behind the plastic fixing studs which allowed them to be pulled out without damage. After a bit of fiddling around the headlining was out and I was able to access the fixings which hold the front of the roof to the window frame. Low and behold the large self tapping screw at the edge of the A-pillar had backed out on the drivers side. I refitted it with a spring washer behind the head and tightened it up - I did the same to the one on the passenger side. Doing this had really firmed up the roof gutter in this region. Refitting the headlining was fairly straight forward. Hopefully this might be of some help to someone else.
Post #553884 5th Aug 2016 2:45pm
Pickles
Excellent result there Stickman, it appears to me that you were lucky it had not been leaking?
Pickles.
Post #553994 5th Aug 2016 10:21pm
shaggydog
That screw is the biggest LR bodge I have ever known.
It's like a wood screw from the 1700's!
Should hold now though if you have added a spring washer Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #554440 8th Aug 2016 11:41am
midlife
Ireland 2007 Defender 90 Puma 2.4 SW Rimini Red
Mines disappeared and the bit of foam it holds into the corner. Anyone have a part number or description so I can order said hoofing woodscrew Many thanks looking on the LRCAT all I see is bolts not a screw. AB614081L is this it ?
Post #554547 8th Aug 2016 7:17pm
