Home > Td5 > Rear replacment LED fog and Reversing lamps |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
I want to replace the rectangular fog and reversing lamps for round ones. I'm thinking LED types. Any recommendations? I've found ones from Britpart, Wipac and Wipac NAS. Are these any good and whats the difference between the UK and NAS standards. Can both be used here?
http://www.paddockspares.com/catalogsearch/result/?q=led+reverse Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
2nd Aug 2016 12:18am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
I've searched high and low for oem look LED rectangular Fog and Reverse
2nd Aug 2016 6:33am |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
I also looked high and low as it were for rectanular led fog and reverse lights and came to the conclusion that if I really wanted LED then they would have to be NAS style round ones. Still like the look of the rectangular ones but I really cant complain about the performance of the Wipac LED ones. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
2nd Aug 2016 6:53am |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 |
I had two of these fitted to the rear of my roof rack. They make amazing reversing lights
Click image to enlarge |
2nd Aug 2016 8:23am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20563 |
Those little Lazer (and larger) lights always get positive reviews.
I looked into aux reverse lights, there are legal wiring requirements and regarding use. However, I never proceeded as I just didn't see the benefit worth the effort and cost to fit and mounting etc. If you've got a pre existing cable run and mounting well then that just makes it easier, you could run wiring down to the front if you wanted to. |
2nd Aug 2016 8:56am |
Lazer make amazing lights. These are meant as work lights and have a separate switch on the dash, but they double up as great reversing lights when needed. I have to be careful where I use them though as they would blind everyone. Not a problem out here in the country though and saves me reversing into a ditch or off a mountainside. I have Lazer ST-4s and RS-4s plus a Triple R-24 on the front. It has to be seen to be believed, crazy crazy light. The Triple R-24 also has a separate dash switch to keep things legal.
2nd Aug 2016 9:06am |
CY88 Member Since: 05 Jan 2016 Location: Offshore Posts: 255 |
If you like things symmetrical, I’ve been really impressed with these dual LED units. Reverse is really bright:
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Quite pricey though and, unless you want to cut the bodywork, you'll also need the plinths and (in my case at least) a couple of large rubber o rings - see 3rd pic) http://www.carbuildersolutions.com/uk/led-...nd-reverse FFRR Supercharged - Series One - Defender 90 V8 |
2nd Aug 2016 9:10am |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
Hi,
impressive! Who did the tailgate conversion? WANTED: SII or SIII in max 1.5k |
2nd Aug 2016 11:28am |
Cheers! Purely Metal do the tailgate hinges. Pretty sure there was a little article about them in LRO recently. FFRR Supercharged - Series One - Defender 90 V8 |
2nd Aug 2016 11:45am |
Riverboy - Assume you have roof spots then? If so similar rules to here then regarding switching...
CY88 - Interesting solution! Not seen those before, allow you to do the double up mod but not add extra units to the rear. I wouldn't say they are particularly expensive, ordinary LED versions are about £25 each so if you wanted 4x of those.. |
2nd Aug 2016 11:52am |
Yes, well one Triple-R 24 on the front of the roof rack which when switched on will come on with high beam, however it's not road legal so has an on/off switch on the dash. Two rear ones only come on via their dash switch. The RS-4s and ST-4s are road legal so come on with high beam, although if I could do this again, I'd only have one pair come on with high beam because all four are a bit too much I think.
2nd Aug 2016 12:18pm |
Great, thanks for all the info and advise, much appreciated. Time to shop!! Mike
2nd Aug 2016 2:46pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
MPS trading do LED versions of the TDi age reverse and fog lights: http://www.ebay.co.uk/itm/272226848080 02' 110 TD5 Double Cab Rebuild Thread
2nd Aug 2016 3:44pm |
