![]() | Home > Maintenance & Modifications > Black modulars? |
![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
A tip to stop modulars (or eight spokes) rusting so quickly.
Apart from dings and scratches, it usually starts in the welded join between centre and rim. So when brand new, run a thin bead of silicone sealant (black or clear) round the join, inside and out, which will keep water from penetrating and keep the old ferric oxide coating at bay. MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Thanks for that - the tip re rust, not the "chiselling"....!!
![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
