Home > Maintenance & Modifications > 300tdi Dashboard - Refitting |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I would of thought the easiest way would be to find a parts manual. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
25th Jul 2016 5:03pm |
Blanc Member Since: 14 Jul 2016 Location: Suffolk Posts: 43 |
I'll try to remember roughly to get you started. This should get you close and use the parts book to help you work out which fasteners go where as it lists them and has an exploded diagram of sorts.
From where you are go for bottom dash on next, followed by the tray that sits within. This has self tappers that screw into plastic inserts in the bulkhead. Next up is the grey plastic grill over the air vents. Don't forget to connect up the heater air hoses when you do this. You can put the wiper motor cover on next as it to makes it all look better. More self tapping screws. I'd then move onto the sides of the instrument binnacle which screw into the bulkhead. Next I'd do the grab handle on passenger side and the trim around the lip of the dash tray Next up I think the heater controls near the drivers door then the top of the dash with vent surrounds. All self tapping screws. Pop the steering colum shroud on then slot the instruments in. Good luck! |
28th Jul 2016 10:53pm |
@ndy Member Since: 08 Feb 2016 Location: Hants Posts: 26 |
As Mash says, get yourself a Haynes manual - I used it to take my 300tdi dash apart, gives a very good step by step on removal and replacing. It's too long to go into in a post as there's lots of steps - good luck
@ndy |
29th Jul 2016 10:14am |
