Home > Technical > Oil Service indicator help
toby9946
United Kingdom 2015 Defender 90 Puma 2.2 Landmark LE Corris Grey
Just noticed on start up a little message saying "Oil service"
It's 10 months old and only done 7,500 miles. It was my understanding that service intervals were a year/12,000 miles?!
Any help much appreciated as I had hoped it's service was not due for another couple of months!
I know if I ask the dealer this question they will tell me it needs servicing now as they will want the chance to empty my wallet!
Thanks all! -2015 Defender 90 XS Landmark-
Post #550843 24th Jul 2016 1:07pm
K9F
It is there for a reason and based on condition not time. Nevertheless if you wish to circumvent this warning and reset it on page two of this thread I posted a couple of ways of resetting it which worked for some. Timing is of the essence so take note.
http://www.defender2.net/forum/topic25462....ight+reset If you go through life with your head in the sand....all people will see is an ar5e!!
Post #550845 24th Jul 2016 1:14pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Re: Oil Service indicator help
Thanks all!
Snap. Mine is same age and a couple of 100 extra miles and has just come on as well. Only difference is - mine has already had an oil/filter change done at approx. 3k.
Post #550848 24th Jul 2016 1:25pm
toby9946
Thanks K9F
Maybe the DPF wants to regen so will take it for a bit of a blast later.
Failing that will try the reset method as oil level is spot on and seems very clean. -2015 Defender 90 XS Landmark-
Post #550849 24th Jul 2016 1:34pm
toby9946
Okay so blast back to London didn't fix it, but reset the indicator with the brake and accelerator pedal method.
Will now do an oil change for peace of mind incase it has indeed got too much diesel in it.
Any recommendations for the weird 934B spec oil?!
Also will the fact the oil service light came on be logged in the ECU now its been reset?
Cheers! -2015 Defender 90 XS Landmark-
Post #550937 24th Jul 2016 7:56pm
spudfan
Ireland
Site sponsor
http://www.advancedfactors.co.uk/06-servic...-210-c.asp 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #551847 28th Jul 2016 10:17am
Martin
Site Admin
Oils list: http://www.defender2.net/forum/topic34176.html
Bear in mind you will now not get a warning when it is due its service.
The Fuchs oil in C2 spec that Advanced Factors are listing does not appear to have the Ford 934B approval. It should be C1 spec.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #551849 28th Jul 2016 10:45am
toby9946
Thanks Martin I had just noticed that it's the wrong spec too!
Actually ordered some Millers C1 from Opie.
It's due it's service end of September so will have remember to get it done then. -2015 Defender 90 XS Landmark-
Post #551851 28th Jul 2016 10:50am
K9F
I wouldn't bother going to the added expense of swapping the oil again in September. Keep the receipt and just let the dealership know it's been done. Change it next time you get the warning. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #551856 28th Jul 2016 11:14am
