Home > Puma (Tdci) > ***Coolant Hose*** Catch it before it bursts |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1764 |
Without knowing the coolant system, a couple of bar on the pump outlet side. I have successfully patched up pipes with self amalgamating tape while waiting for parts, just have to prep and clean the area well
27th Jul 2016 7:01pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Right it's the hose from the water pump, I have found a few parts diagrams but only for the 2.4. Does anyone have one for the 2.2.
27th Jul 2016 7:55pm |
I'm after the latest 2.2 puma page as shown below;
The puma equivalent of part 8 is what I need. Click image to enlarge |
27th Jul 2016 8:15pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20473 |
On the 2.4 where a hose goes past the PAS header, is one to keep an eye on too, as well as various clips can come off.
These hoses are surprisingly expensive too.. |
27th Jul 2016 8:57pm |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
This maybe time too go full silicone pipe kit! You may change out the coolant as well, I always lose a little however carefull too collect it as I drain! Just done the MGR like this for peace of mind. Rubber pipes after a few years are too me always a concern on big trips, you can examine but I don't know a sure fired way of telling if they are good!
27th Jul 2016 11:57pm |
Staftly Member Since: 06 Jul 2012 Location: Lancashire Posts: 55 |
Same happened on my 2012 2.2. This is a known issue and should be fixed by your dealer. They replaced the pipe and added a few cable ties here and there. I think the new pipe is a slightly different shape so as to avoid a reoccurrence. I would certainly take it up with your local dealer.
28th Jul 2016 10:03am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Possibly LR049202 - if that hose turns away from the camera where it goes out of site and into the water manifold?
Look at the water pump section of the parts catalogue - G04016 http://new.lrcat.com/#!/1235/3714/4066/316 1988 90 Td5 NAS soft top 2015 D90 XS SW |
28th Jul 2016 10:52am |
