![]() | Home > Puma (Tdci) > Random Bolt |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
I had one the same in mine
So did I, except mine had fallen off the lock. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
I may have pointed that out to ![]() ![]() ![]() You find if they drop a nut in production they dont pick it up as it costs time they get a new one Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
ricey Member Since: 01 Nov 2010 Location: Sydney Posts: 1 ![]() ![]() |
Just back from the dealer, having found two nuts before, they investigated. It seems that they came from under the trim around the sliding window. I'm guessing what holds the tub to the canopy the dealer said all nuts were loose front to back.
Pete |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 ![]() ![]() |
Yip thats what I also found.
szracer Member Since: 10 Oct 2010 Location: Cotswolds Posts: 356 ![]() ![]() ![]() |
Never understood why LR don't fit these as standard....
![]() ![]() 2010 110 XS USW (the slow one) 1960 Alfa Romeo Giulietta SZ (the fast one) 2005 Ducati ST3 1954 Sunbeam S8 |
That type of nut is part of the roof to side fixings 130's have feeling's as well you know
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Yep,, hard to explain but,, If you take off the rear side window panel, at the bottom centre there is a oblong hole, with a capping bolt going down thought a bracket, them another bolt through the side !! Had it all to bits on Monday, fitting the internal guards !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
This is also where I found my nuts missing. |
