Home > Td5 > TD5 centre console and dash binnacle tabs.
DC101
United Kingdom 2003 Defender 110 Td5 DCPU Epsom Green
Hi,
Two of the top three tabs on my centre console are broken, as per photo:-
Any solutions, or am I to hunt around for a good used item?
I appear to have a similar problem with the bottom part of my dash binnacle.😟
With thanks
Post #551224 25th Jul 2016 9:15pm
mk1collector
Can't see the pic. Ray
My build thread
Post #551234 25th Jul 2016 10:00pm
DC101
Thanks, try again!
Post #551239 25th Jul 2016 10:31pm
lightning
Probably easiest to get a replacement, check to see how much it costs new. You could cable tie it in place by drilling a hole in the remains of each mounting, plus another in the main dash where the mounting is, then put a cable tie through both holes.
Post #551260 26th Jul 2016 6:55am
Anderzander
You can buy them new, but they are quite expensive, and second hand they seem very sought after - so I'd try gluing new tabs on first. I've not done it myself, but abs plastic is supposed to be quite easy to work with.
Having said all that - if you do buy a replacement I'd buy this broken one, which might offset some of your costs?
Post #551264 26th Jul 2016 7:11am
mk1collector
Just use a big washer under each screw to clamp it down. It's not and area that should get much pulling about. Ray
My build thread
Post #551320 26th Jul 2016 11:23am
DC101
Thanks All.
Replacements appear rare, and had a quick look on-line last night- £180 from a supplier!
I'll try the washer route and see how it hangs on!
Cheers,
Robin
Post #551325 26th Jul 2016 11:40am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I've successfully repaired a couple of very similar broken tabs on the instrument (Clocks) binnacle on my 90.
I found a bit of a broken casing from an old scrapped TV of a similar thickness and type of plastic and fashioned some replacement tabs to fit in place of the broken off bits, then glued them in place with PVC pipe adhesive, I clamped them in place while the glue set and just tidied up around the edges and now they're as good as new. Thumbs Up
Post #551328 26th Jul 2016 11:55am
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
If you know anyone with a 3D printer they could print some replacement tabs for you with a suitable way to attach them to the existing surround. http://www.yorkshireoffroadclub.net/
Post #551329 26th Jul 2016 12:02pm
mk1collector
If I remember correctly the tabs are only like a 2 prong fork anyway so it's just the screw clamping down that holds the console in place so washers will be fine. Ray
My build thread
Post #551364 26th Jul 2016 2:59pm
