![]() | Home > In Car Electronics > Ariel Baffoonary! |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1033 ![]() ![]() ![]() |
Hi all
After my encounter of the bovine kind a few weeks ago , where the bent my ariel over it finally gave up the ghost and fell off! So armed with previous threads I trotted off , got a replacement and started to swap it with the now defunct one Tie some string to the old cable and removing the radio I successfully got the old cable through with the sting attached to new cable. Yep you guessed halfway through the string broke before the cable could get to within sight or reach , so does anyone know if there is an easy way to get the cable back through or is it a dismantling job on the dash ? Cheers Greg |
Should have said I did try the coat hanger thing , with the tip taped to avoid damage , got it so far but still could see or feel where it was , even with the centre thingy out !
foxyred Member Since: 16 Jul 2016 Location: Nottingham Posts: 227 ![]() ![]() ![]() |
Go to Screwfix buy a cable and flex draw tape £ 9.99
one of the most useful £10 you will ever spend |
GSLRO Member Since: 13 May 2012 Location: Tyne and Wear Posts: 499 ![]() ![]() ![]() |
Or try some net curtain wire with good ole gaff tape
http://www.ebay.co.uk/itm/like/30191423171...amp;crdt=0 Adventure isn't paved! |
