Home > Puma (Tdci) > Random Bolt |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
How big is the nut? Mike
25th Jan 2011 8:06pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Might just be spare from when made I found 1or2 floating about.
25th Jan 2011 8:07pm |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 |
isnt that the master bolt nut, you know the one that holds the two sides of the chassie together?
sorry i'm a child i know, it does look like the nuts that are used to hold the tie down's, i know they are used in other places, just not sure where. |
25th Jan 2011 8:18pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Yup, looks like a lashing eye nut.
25th Jan 2011 8:26pm |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 |
primary gearbox mount retain nut......is it about an M6 - M12 in size?
25th Jan 2011 8:59pm |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 |
lashing ring nut, should be under your vehicle. WANTED:
SII or SIII in max 1.5k |
25th Jan 2011 9:03pm |
Apynala Member Since: 17 Oct 2009 Location: Morroco Posts: 88 |
I've found the same at the same place, I've put it in the cubby box tilt I know where it came from. |
25th Jan 2011 9:36pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
me too www.newfoundland.gr
25th Jan 2011 10:04pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
pha...... you lot know nothing. it's the doubry nut that's holds on the ferkin thingy BM52
25th Jan 2011 10:08pm |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
Ha it is smaller than a rear door bolt I know that. Washer is attached but it spins. Clearly my truck is going to explode.
25th Jan 2011 10:17pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
It's a gift from land rover to you One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
26th Jan 2011 6:20am |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 |
Click image to enlarge Check one of these nuts. I had the same gift by LR. Ciao Vinicio Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
26th Jan 2011 8:17am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
prob been rolling around since it left the production line as no spanner marks etc on it. 2.4 90 XS
26th Jan 2011 9:15am |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
I found 3 of them...1 was under the plastic surrounding the windows causing an irritating rattle that the dealer could not find.
I am taking the plastic off this weekend to see where they come from. |
26th Jan 2011 3:36pm |
