![]() | Home > Td5 > TD5 Diagnostics |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
If it's any help, timing is mechanical, there's no electronic adjustment to it as such. Injectors you can only check the trim codes are correct for the injectors and look at cylinder balancing which unless you are looking for a pretty much dead miss are a pretty useless set of figures.
Funkykipper Member Since: 05 Oct 2012 Location: Nuneaton Posts: 13 ![]() |
Thanks Slim, I think I've reached the limit of my ability with this engine so I'm looking to get the injector rail set correctly (the adjustments on the cam rail)
The timing checked in case i have missed a tooth or something like that and check the correct map on the ECU. The Green Lane Association. |
Shame you're not a bit closer I'd happily do it for you. Are you having problems with it ?
It's just running a bit lumpy and is prone to puffs of smoke.
Sounds all to familiar with age ![]() ![]() ![]() |
oil in red ecu plug
So far I have replaced:
5 injectors The injector harness The cylinder head Turbo There was oil in the loom but that has now displaced. I just think it needs a proper check on a diagnostic tool and somebody who understands td5 engines to check the injector settings, cam lash, timing. The Green Lane Association. |
Injector seals are cheap to replace and if the old ones are shot it can make a big difference to running. Ray
ok
Any particular driving conditions that make it run lumpy?
It's lumpy on tick over.
Driving is ok but does kick out a fair amount of black smoke The Green Lane Association. |
