Home > Td5 > TD5 wont start, no noise from fuel pump, temp gauge cold |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 |
Check that the fuel pump relay is being woken up by the ECU. Under driver's seat the yellow rear relay, waggle it, tighten the spade with thin pliers and generally encourage a good connection. Have you got any chip performer add-ons under there? On my 2005 90 this has been a real pain. Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ... |
19th Jul 2016 9:07am |
Little Tom Member Since: 20 Aug 2013 Location: Lancashire Posts: 134 |
No chip add ons, well not that I have added, I assume it would be fairly obvious if there was one. I will check that relay and give it and the red ECU a clean with electrical cleaner and see what happens...
Any other suggestions? Michael was just telling me a story about a friend of his who slept with a land rover, lonely nights in the desert.. |
19th Jul 2016 10:30am |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge start with earthing i.e. battery to chassis , to transfer box and chassis to body drivers side underneath, next fuse driver seat box and so on good luck do you have voltage tester ? |
19th Jul 2016 11:04am |
