Home > Maintenance & Modifications > Swingaway recommendations
Page 1 of 4 1234>
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
It doesn't look like even the latest MY2011 incarnation of the Defender has seen any improvement in the quality of the rear door hinge strength. Up until now I've always automatically replaced the door mounted plate with a Mantec swingaway.
Things look like they've changed in the marketplace with more choice now? I've got my new motor coming soon and I'm looking for informed recommendations for the best current altermative to leaving the wheel hanging off the back door.
Which ones are best? Which keep their powder coating on? Which are silent/vibration-free? Which are the strongest? Easiest to fit?
Cheers in advance.
Ade D300 HSE 110
Post #54910 25th Jan 2011 10:30am
BigMike
Mantec one is very good. Bearmach is cheaper but not quite up there in terms of quality. Safari Equip does one but I've heard of several people having issues with it. Their other gear is well made however.
Post #54913 25th Jan 2011 10:52am
Zagato
Nice to have a 'SYF' Wink
Post #54918 25th Jan 2011 11:18am
Lorryman100
Ade, I have the nakatanenga one fitted to my Landy. It is very well made from steel first galvanised before being powder coated. Where the swing away arm meets the guide plate both bits are stainless steel so when the powder coat wears away it wont rust. The weight of the carrier and wheel is carried by the cross member with all the weight removed from the rear door. Here is the thread I done on fitting it:
http://www.defender2.net/forum/topic4659.h...el+carrier
HTH Brian.
Post #54920 25th Jan 2011 11:21am
BigMike
Nice job Bri.
Post #54924 25th Jan 2011 11:29am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
There is also this one Whistle
Post #54926 25th Jan 2011 11:32am
18stone
Thanks chaps. I've also now bothered to find the previous threads on much the same subject and there's plenty to chew over.
Sorry for duplicating a much-visited subject Embarassed D300 HSE 110
Post #54927 25th Jan 2011 11:37am
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
Have to say, I've got the Alisport / Sonic one, and cannot recommend it highly enough. Strong enough to carry at least 2 wheels piggy backed (with longer bolts - if you needed too), smooth, well made, and all the weight on the crossmember.
Bloody heavy though - you MIGHT want a wee hand to get it installed - just 2 minutes help until the main bracket is mounted.
Yes it is more expensive than the rest but you get what you pay for.
(Right Sonic, when do I get my commission Whistle ??) 2001 TD5 110 DCPU in Bonatti Grey
Post #54931 25th Jan 2011 11:47am
Sonic3d
How about several beers if you visit us at any of the shows Thumbs Up
Post #54933 25th Jan 2011 11:54am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
I have the Mantec one.
Does the job very well but my powder coating is coming off in parts (around the hinge) after 3 years. Bit disappointing.
I wouldn't be without one - rust or no rust.
Sonic's looks good but wasn't available when I bought mine. important that it stays attached to the back door. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #54959 25th Jan 2011 4:12pm
daviec1
The Sonic one does not attach to the back door, thus making it ideal for tailgates.
It simply open completely independent of the vehicle, with all the weight on the crossmember, nothing on the tub, and no drilling into the bodywork, or anywhere else as it uses existing holes in crossmember. 2001 TD5 110 DCPU in Bonatti Grey
Post #54970 25th Jan 2011 5:02pm
Surrey Rover
What is the cost of the Sonic one please and any other pictures of it?
Post #54978 25th Jan 2011 5:41pm
BigMike
ebay item eBay Item No. 330484485039
if you do a forum search there is a thread which sonic started with loads of pics.
Post #54979 25th Jan 2011 5:47pm
Surrey Rover
Thanks Mike.
Post #54994 25th Jan 2011 7:17pm
bob neville
SR
Some pics in my gallery - excellent bit of kit Thumbs Up
Bob
Post #55004 25th Jan 2011 8:12pm
Page 1 of 4 1234>
