![]() | Home > Puma (Tdci) > Brake Fluid Specification |
e.khromtsov Member Since: 23 Mar 2015 Location: Arkhangelsk Posts: 7 ![]() ![]() ![]() |
MY07 WSM:
"If the above fluid is not available, use a low viscosity DOT 4 brake fluid meeting ISO 4925 Class 6 and Land Rover LRES22BF03 requirements." MY07 Maintenance Check Sheet states 24 months / 24k miles as brake fluid change interval. I use "ROSDOT6" (DOT4, ISO4925 CLASS 6, has no LR approval) brake fluid. It costs only 300RUB (approx 3.55GBP) per liter, so I change it every year. |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1821 ![]() ![]() ![]() |
![]() Click image to enlarge Handbook for MY15 if it's of any assistance Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4043 ![]() ![]() ![]() |
I've been trawling the otherwise extensive service record on my 07 110. Receipts for everything except for a brake fluid change! The fluid looks dark too, which it would if over 9 years old! Assuming the nipples aren't seized solid (they don't look good) think it might be wise to put new in this afternoon.
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 ![]() ![]() |
Many thanks for the info 👍
I guess the clutch fluid needs doing every two years also?
Any tips for how to bleed through the clutch? Cheers Mark |
