Home > For Sale & Wanted > [Wanted] Vent cover panels
Super7
United Kingdom 1999 Defender 90 Td5 CSW Rutland Red
I'm looking for a pair of vent cover panels if anyone has a pair they'd like to sell? Part number MTC6109
Thanks Very Happy
 '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #549019 15th Jul 2016 5:42pm
jrule
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
What's the point of them?
Post #549025 15th Jul 2016 5:52pm
Super7
I want to use them to blank off my vents.
Getting fed up with leaks Big Cry '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #549028 15th Jul 2016 5:59pm
jrule
Ahh I see, sorry I've never seen them before and was interested in what they did.
Post #549057 15th Jul 2016 9:16pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
You know they are basically trim panels for early AC-equipped trucks which had no vents from the factory right? I'm not sure they would do much blocking off. I mean, they go in the space but you'd have to rig up something to seal them and then I'm not sure they'd ultimately be that effective. I would think something using the actual covers would work better.
Post #549090 16th Jul 2016 5:07am
Bps
Have you exisiting vents got the rubber seals attached to the bulkhead or the ones attached to the vent flap ? Input new bulkhead side seals on with a flexible adhesive and it stopped any leaks. Have you checked the windscreen rubber and the seal in between the the windscreen frame and bulkhead ? I've also had leaks through the screen mounting block bolts
Post #549101 16th Jul 2016 6:27am
Super7
Yes, I was going to worry about sealing the blanking panels if I managed to get hold of a pair.
I have newish seals on the flaps, and new rubbers all-round, and I thought it was fairly leak free. I've just spent 2 days pulling the dashboard out and tracking down an electrical fault. It looks like one of the electrical headers has corroded crimps due to water running down the loom.
So I'm happy to loose the vents if it helps to keep water out Thumbs Up '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #549119 16th Jul 2016 8:31am
Bps
Have you checked the grommets on the bulkhead where wiring goes through from the engine bay ? Some of mine were perished or had been pushed through
Post #549124 16th Jul 2016 8:55am
Super7
Thanks, yes checked those today - they're in pretty good shape Thumbs Up '99 TD5 Defender 90
'52 Series 1 80"
'99 Caterham 7
Post #549187 16th Jul 2016 7:05pm
