![]() | Home > In Car Electronics > Connecting an Engel Fridge to a Blue Sea Dual Battery System |
Assuming you've got a fuse box with screw terminals, you just need a ring or fork terminal on the end of the fridge lead.
Have you got the tools to crimp them? If not you need something like this, other suppliers are available. https://www.beal.org.uk/heavy-duty-heavy-d...mpers.html Generally they're colour coded, red up to about 1.5mm2, blue up to about 2.5mm2, yellow up to about 6mm2. For this job, either a red or a blue would be suitable. Then you just need to find one of the correct size to fit in to your fuse box. |
Galyman Member Since: 20 Jan 2016 Location: Scottish Borders Posts: 92 ![]() ![]() ![]() |
Thanks Cupboard
I was not sure if the colour coding on the wee connectors indicated a load or cable size. I found a crimping tool in the depths of the workshop so all sorted now with fridge hooked up in advance of trip up the Pyrenees. Need a cold beer up the top. |
![]() The colours indicate a size which then dictates the load, so it's all related. |
