Home > Maintenance & Modifications > Rotten / Snapped Door Top Corners
dan_miles86
United Kingdom 1998 Defender 90 300 Tdi HT Barolo Black
Hi all,
Just got my first defender and started working through all the problems.
I've removed the door cards to try and fix the interior lock buttons. What I revealed is the mounting points in the top corner have rusted and snapped off. One side is a bodged repair, the other side has the whole section missing.
The rest of the door doesn't seem too bad so is there any way these can be repaired?
Cheers,
Dan
Post #547511 10th Jul 2016 11:22am
dorsetsmith
you can get top door repair section i trying to remember who is making them now and all you will need to do have weld in place
fond it on this link
http://www.sp-4x4.com/DEFENDER_DOOR_REPAIR_SECTION_p/sp235.htm
this right hand door piece and in same site you will find LH door piece
you can see one door with window and winding mec missing and red arrows show the parts you have and problem with
Post #547528 10th Jul 2016 12:47pm
sako243
YRM metal solutions? Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #547530 10th Jul 2016 12:52pm
dan_miles86
There seems to be lots of sections but I can't find that bit. Are these not common? Don't really want to have to replace the whole door for that bit.
Post #547565 10th Jul 2016 3:36pm
dan_miles86
dorsetsmith thank you for making my first intro to the defender scene a good one!
I spent a few hours looking for that.
Thank you!
Post #547585 10th Jul 2016 5:44pm
dorsetsmith
not problem Thumbs Up
I'm in the process re skinning two door with steel gav skins diver door completed had to repair door frame and paint it be for fitting skin and finishing paint work fitting the door also wax oil in the door frame to slow down rust
Post #547588 10th Jul 2016 5:54pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
that's brilliant. Sp4x4 are less than a mile from my house and I need these too! 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #547666 10th Jul 2016 9:00pm
gazman
Post #547677 10th Jul 2016 9:48pm
