Home > Td5 > 2003 TD5 90 Defender 90 - gear issues |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
mine does it. just take your time especially when cold 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
7th Jul 2016 6:53pm |
EWS Member Since: 29 Nov 2011 Location: Bristol Posts: 156 |
06 model , the same . blip the throttle as if you are double de clutching, I blip the throttle now before every gear change, just reminds me of my first truck , a 54 series 1)) or get used to making a slow change , seems to help the syncro's . Reverse sometimes seems to stick in gear , but only for a fraction of a second, just seems standard on this model box, just don't rush it, ours been like it from new.
Somewhere I did read about a oil that was supposed to help with these problems, thinks the DIFFLOCK site had info on this |
8th Jul 2016 8:40pm |
Wism Member Since: 27 Jun 2016 Location: Surrey, UK Posts: 21 |
So I hear back from the dealership that they couldn't really find much of a problem with the gear changing, "it's just normal for that age and model but we have decided to replace the clutch" ...... I just hope they don't just stick in a used clutch.
Thanks for all the advice |
14th Jul 2016 5:12pm |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2893 |
I don't think they will put a used clutch in....after all, they'd have to take it all apart again if it didn't work properly. A new clutch is not expensive.
15th Jul 2016 7:20am |
New clutch has been installed and it's so much better. Thanks all
27th Jul 2016 4:54pm |
What did l say!!
28th Jul 2016 9:02am |
Spot on lightning
28th Jul 2016 12:29pm |
