Home > Puma (Tdci) > ABS light
CapeLandy
South Africa
ABS light
Just reading somewhere els that someone had an ABS light staying on.
Mine stays on for about 2 min of driving then dissapears.
Is this normal or should I get it checked out?
James Puma 110 - gone
Series III 1973 - going strong
Post #5395 9th Dec 2008 6:41pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Dealer told me it should remain on for about 30 seconds after starting and moving off and then turn itself off.
Post #5397 9th Dec 2008 7:29pm
Bosun
2008 Defender 90 Puma 2.4 XS CSW Tonga Green
Someone correct me if I'm wrong, but I thought it went off once you got above a certain speed after driving off. Say 10kph or so.
Bosun.
Post #5403 10th Dec 2008 7:11am
Grockle
As DAZ says about 30 secs after moving off. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #5404 10th Dec 2008 8:23am
CapeLandy
South Africa
ok then
I suppose it is about 30s after mooving off as it stands and idles a bit before I get going.
Thanks chaps Puma 110 - gone
Post #5405 10th Dec 2008 8:34am
DAZ110
Yes, I think you need to be moving for the light to turn off.
Post #5407 10th Dec 2008 10:42am
Laurie
Doesn't the handbook say anything?
My TD5 book says after reaching 5mph.
Post #5409 10th Dec 2008 12:02pm
chalky
the ABS light should extinguish once it has completed it's own system check and breeched 5 mph.
If u drive at 4 mph all day itshould stay on !
In theory any way ! DEFENDER XS CSW 08 TONGA GREEN
Post #5413 10th Dec 2008 7:34pm
Trevor Wright
In my experience, the ABS light remains on if you start up and then reverse, but once you move forward, after a few wheel revolutions it goes off. I don't think there is a simple timeout - I guess the electronics are looking for so many clicks from the wheel sensor in forward motion.
I wonder if the ABS works when reversing ? Trevor Wright
'08 90 TDCi/TD4 XS SW
Post #5457 13th Dec 2008 10:15am
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
The ABS light will remain illuminated untill you exceed abbout 20 Km p/h. If you idle it will stay on. As soon as you reach +- 20 km p/h it should switch off.
Post #5468 13th Dec 2008 8:23pm
Rocket123
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Epsom Green
This maybe similar. The ABS warning light on a BMW motorbike does not extinguish until the system has undertaken a self test which requires rotation of the wheels for a few yards. I expect a similar system operates on the Defender.
Also some ABS systems don’t modulate the brakes at less than 5 mph (which may be the case with the Defender?) and therefore it is necessary to exceed or reach this speed for the diagnosis to be run.
BMW may run this self test because of a number of fatalities caused by ABS servo failures which reduced the braking capacity of the bike by about 50%, although the latest bikes are now non servo systems. Maybe there is a greater risk of loss of control as a Defender might be parked/stopped in an off road position or with a heavy trailer where ABS might be relied upon, and thus the light is warning to proceed slowly until the test is completed.
It’s dissappointing that the manual supplied with the vehicle has next to nothing about the operation of the ABS or Traction Control.
Rocket
Post #6034 7th Jan 2009 7:31pm
