Home > Wheels & Tyres > Newbie question! |
LoveTheMud Member Since: 19 Feb 2015 Location: Weybridge Surrey & Pontefract West Yorkshire Posts: 411 |
Welcome amhobbs,
Twisted tailor your defender to your requirements as well as producing generic models. It depends on which version you were looking at, some have standard ride height others are lowered. Hope this helps initially before some of the other members respond. Cheers Michael |
5th Jul 2016 8:55am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7905 |
Hi and welcome to Defender ownership and Def2
With a 110 the rear is often lowered by 1" to get the vehicle to sit level. Various companies do 'kits' like Twisted, Alive Performace, Urban Truck, IRB or you can just buy the parts yourself. I can't help with the specific item part numbers as it would depend on what you actually want to achieve i.e just visual 'sitting' of the vehicle or improved ride etc? Hopefully someone else will help with specifics James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
5th Jul 2016 9:58am |
amhobbs Member Since: 05 Jul 2016 Location: Quebec Posts: 2 |
Thank you guys.
I'm trying to get better handling and get it to look like this one. Thoughts? Click image to enlarge |
5th Jul 2016 10:49pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3750 |
Hello
You say your new to Defenders so probably had a normal car previously? (like me) I have a 110 and to be honest its not too bad in std height once you get used to it, maybe live with it as it is for a little bit while you get used to it? OK its no sports car but progress through the bends can be made (even more so without passengers) |
6th Jul 2016 8:58am |
1978 Member Since: 04 Aug 2015 Location: Lancashire Posts: 519 |
If it helps, the wheels in that photo are Overfinch Apollo 18". http://www.overfinch.com/defender/apollo/ Twisted use tuned Eibach springs and anti roll bars, with Bilstein B6 Dampers and steering damper: http://twistedautomotive.com/store/twisted...on-system/ The standard Bilstein B6 shocks & dampers are far cheaper and supposedly very good without additional specific tuning. http://www.flatdoguk.com/bilstein---def-from-td5~498 |
6th Jul 2016 9:03am |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2892 |
I have gone for the twisted kit with -1" rear.
Also look at JE, they use standard front springs and then a -1" rear so another setup. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
6th Jul 2016 9:48pm |
