![]() | Home > Puma (Tdci) > What grunt |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
Thanks MK,no it's a grunt once the engines fired not the knocking you're referring to 2.4 90 XS
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
Yep - they all do it - normal.
Nice RM Williams boot there,what is the noise do you know ? 2.4 90 XS
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 ![]() ![]() ![]() |
I,ve got a pair just like them !
And i cant say i,ve noticed a grunting noise ! You havent got somebody stuck underneath yours have you ? DEFENDER XS CSW 08 TONGA GREEN |
I've got a pair too, no there's no one under it, perhaps it an export model as I'm with Russell's does. 2.4 90 XS
Maybe russels does it cos its upside down
![]() Which again doesent detract from the point that yours does it too. Strange how when you start to look at other peoples interests and objects how similar tastes are ! Not counting the obvious Land Rover thing ! We should start a list to see who has what ? DEFENDER XS CSW 08 TONGA GREEN |
Yep - it's the rubber band winding up - either that or it's the brake system pressurising the ABS modulator on the firewall right in front of the A pillar. |
Thanks mate, I had the dealer swop the starter motor incase it was grinding on the flywheel. 2.4 90 XS
Chalky,you go first then. 2.4 90 XS
one_iota Member Since: 06 May 2008 Location: Sydney Posts: 99 ![]() ![]() ![]() |
![]() R M Williams boots are my daily footwear... I'll be be buried Viking-like in a Land Rover wearing them. (albeit upside down) I have to send them to South Australia for servicing as they leak Mahn '08 Defender 110 ex '95 Disco 300 Tdi www.aulro.com |
OK Grockle,
Shotguns ? DEFENDER XS CSW 08 TONGA GREEN |
No Chalky don't have one,but our 90 is Tonga Green like yours 2.4 90 XS
Ah, There you go then more in comparison..... DEFENDER XS CSW 08 TONGA GREEN
