Home > Maintenance & Modifications > Gwyn Lewis Mud Flap extensions |
In that case all you need is the plastic mud shields and you can leave the front flaps alone.
4th Jul 2016 3:52pm |
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 750 |
As correct as you are Cupboard I do think it looks better when they are moved so may have to accept less muddy doors 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home M0XQS |
4th Jul 2016 4:03pm |
fair enough.
Get some spray on mud for your Landie? |
4th Jul 2016 9:59pm |
Spray on mud...............I'm sure that was a BMW thing they did when they launched the X5
I think I'll go with the deeper muddier puddle option. Much more fun 1995 300 Tdi Epsom Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
4th Jul 2016 10:02pm |
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 406 |
From new the first thing I did after getting dinotrolled was to fit Gwynn Lewis guards front and back to my 90HT.
Fronts easy fit. However I did buy the rubber mudguard relocation kit, but have not fitted it yet. Not sure about the look, but can't fault the quality of the kit. The rear X member kit was easy enough to fit. Front of rear wheel arch are a little more difficult as you need a second pair of hands to help do up the bolts. You need to trim to fit depending on your model. Altogether quite easy to fit. They do exactly as they are meant to and come recommended by me. |
5th Jul 2016 6:24am |
I haven't done the rear crossmember shields, just the ones that go above the mud flap. Do the crossmember shields add much?
5th Jul 2016 6:56am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
I'll probably do the fronts on mine first Phil, bored of having muddy water chucked all over me when the window's open!
5th Jul 2016 10:10am |
