Home > Technical > 2.2 engine management light/"limp mode" |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1972 |
I had the exact same experience with a D4. 20 days and hundreds of test miles with the dealer and no fix. I traded it back to them. Their diagnostics aren't precise enough to be of any value, they leave too many variables to check, all the while you the owner lose confidence. Very frustrating. I hope you get it sorted out.
3rd Jul 2016 9:08am |
allyjbull Member Since: 16 Nov 2010 Location: Northumberland Posts: 74 |
Confidence is very low especially in main dealership, they just don't seem interested. I'm taking it to an independent Land Rover specialist this week in the hope they can suggest something.
3rd Jul 2016 10:53am |
Sarawakboy Member Since: 05 Apr 2015 Location: Sarawak Posts: 5 |
Hi, i have the same problem with my Puma from New. You can search the Forum about this issue. Its probably your Turbo hose. Check it for leaks ( rev your engine and see if the turbo hose leaks.). I had the 'Limp home mode ' came on every time i gun the engine up a hill or accelerate out onto the highway. My turbo hose blow a hole near the jubilee clip). Basically the engine ecu is getting a different reading from the Airbox MFS and the air intake into the engine. Resulting in a error code and your engine will go into the 'Limp home ' mode.
I had my turbo hose replaced with the Silicon hose and it has been fine ever since. |
3rd Jul 2016 3:50pm |
Turbo hose has been replaced under recall I think, but I'll check.
I've had it on the laptop at a independent garage this morning and 2 faults show up which are both throttle/pedal position sensor/switch voltage, signal compare failure. So hoping to go to main dealers with a bit more ammo than usual. |
4th Jul 2016 10:47pm |
Nick-St Member Since: 23 Apr 2013 Location: Surrey Posts: 267 |
Mine had the same issue - it was an intercooler leak. Replacement intercooler fitted & all done. It was diagnosed on the second go!
29th Jul 2016 4:45pm |
