Home > Td5 > TD5 ticking noise
michaelwl
South Africa 2002 Defender 110 Td5 SW Alpine White
TD5 ticking noise
My 2002 TD5 has during the last few days developed a ticking noise coming from the engine bay during acceleration.
If decelerating then ticking does not happen only under acceleration. Everything else appears fine. No loss of power, no smoke, just this annoying ticking sound.
Any ideas from the forum experts appreciated.
A few more general questions. I have a nanocom tester. What should the max values be for:
1 Turbo pressure.
2 ambient air pressure
3 Wastegate
Thanks in advance. 2002 110 TD5 White
1981 S3 R6 Matt Green - Now used as game viewer
2013 Discovery 4 XS
Post #543232 25th Jun 2016 9:49am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Ticking noise under acceleration could be coming from an exhaust manifold leak.
Don't know about the NC values.
Post #543238 25th Jun 2016 10:18am
michaelwl
Thanks Clive.
Leak in the exhaust compression pipe as it enters the manifold. 2002 110 TD5 White
2013 Discovery 4 XS
Post #545349 2nd Jul 2016 4:24pm
cobra_mark
United Kingdom 2000 Defender 90 300 Tdi SW Barolo Black
Any idea where that pipe is I have a ticking noise which goes away after 4-5 miles wondered if it was also a small leak
Post #545436 2nd Jul 2016 8:57pm
michaelwl
Cobra Mark,
You can see it here in the pic below. It's the compression joint that's in the exhaust just below the manifold joint.
 2002 110 TD5 White
2013 Discovery 4 XS
Post #545529 3rd Jul 2016 8:01am
cobra_mark
Thanks will check it out, having the tensioner and pulley bearing changed anyway due to age, may look at the viscous fan as a warm engine makes no noticeable noise.
Post #545590 3rd Jul 2016 11:28am
james975
Scotland 2000 Defender 90 Td5 HT Epsom Green
Did you get to the bottom of the noise
Post #743406 1st Dec 2018 3:04pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
I posted a similar question just a little while ago... had similar responces... but all went quiet when I went to check, last night I had a little tapping but not had a chance to check anything yet...
heres my post thread...
https://www.defender2.net/forum/topic64835.html Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #743421 1st Dec 2018 3:52pm
