![]() | Home > Puma (Tdci) > Reversing light |
AndyTunn Member Since: 10 Jan 2015 Location: Auckland Posts: 313 ![]() ![]() ![]() |
My reverse light has stopped working. So far I have:
1. Swapped reverse and fog light and proved that the light itself and the bulb is OK. 2. Checked the fuse is OK. 3. The reverse light is plugged into a Mudstuff piggy-back loom to feed out to the work light, but I've checked that is OK too. My next step was to check the reverse light switch at the gearbox. Using the tips on this thread (although I can't get the photos to work) I've found the switch via the access panel under the cubby box. ![]() Click image to enlarge The switch seems to be properly tightened up. My plan was to remove the connector from the back of the switch and check if I could get the circuit to work by by-passing the mechanical switch but I can't work out how to get the connector off! I know it's a "squeeze to release" connector of some sort, but I can't work out which bit I need to squeeze! I've tried just about every part I can but it all seems totally solid - no obvious give anywhere. Access is really tight so maybe I'm just not getting enough pressure to the right bit. Does anyone know how this type of connector works? Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Had a cup of tea and a think and tried again. This time I got it, and when I short circuited the connector everything worked as it should. Looks like I need a new mechanical switch then!
mine played up
took old one out and it was full of oil , then found gearbox was overfill did get the switch working by washing it out , but replaced anyway bit of a pig to get at from underneath , but doable |
jonesie Member Since: 25 Sep 2011 Location: Petworth Posts: 231 ![]() ![]() ![]() |
![]() Click image to enlarge Cleaned my switch today all seems fine now I did ponder doing the job though because I didn't have a stubby 22mm spanner...... However much trawling later I found the perfect tool and guess what? It cost £1.50 from screw fix ( nothing these days costs £1.50! ) Bottom line get one of these spanners. Jonesie the thrifty. Series I 86" Petrol orig side valve (daily hack) VW Tiguan ( bit bland but very comfy ) Porsche 997.2 790 Bonnie |
cinqetoiles Member Since: 31 Jul 2012 Location: Belgium Posts: 4 ![]() |
![]() Click image to enlarge Did it entirely from underneath. The trick is to find the right position for your arm. See picture. Quick job, as there was nothing to dismantle. |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 ![]() ![]() ![]() |
Thanks for all the advice in this thread, espically blackwolf, new switch fitted and seems to have cured my intermittent light. My 90 Project : http://www.defender2.net/forum/topic52774.html |
Essex Lad Member Since: 15 Jan 2018 Location: Brentwood, Essex Posts: 1 ![]() ![]() |
I just had the same reversing light switch issue with my Puma 90 2.2 hard top. Couldn't get close to it from below so took the gearbox tunnel off from the inside. It only took 1 and a half hours to replace the switch (22 mm spanner) but I have rubber mats so it could be more difficult if you have carpets fitted. Mine has only covered 15k miles so no idea why such a simple switch should fail like this but it had ford stamped on it so I suppose that's the reason!
Not a difficult job, hardest part was removing the rubber mat from around sticks and hand break. Here are a couple of photos showing the switch with the tunnel removed. |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2299 ![]() ![]() ![]() |
Hello All
Well mines gone the same way (probably) 2010 2.4 50K... intermittent then nothing. Been Reversing with Hazards for a week or so (not ideal) Fuse + Bulb OK so hoping that its a 'simple' Switch Swap Out... Just as an Update LR Part Number for a Reverse Light Switch MT82 Transmission 2007-2016 Was LR005160... ![]() Now LR077773 SKIP https://www.defender2.net/forum/topic83242.html |
This came up on another thread a few days ago. With a bit of perseverance, the switch can be changed from the panel under cubby box. More details here:
https://www.defender2.net/forum/post733726.html#733726 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Thanks LRA Darren
I saw this subject on Conāfuseāion! but the link to your story is really helpful... ![]() This is going to be my way in also, I think I have a (thin) stubby 22mm Spanner in my Cycle Tools but if not a bit of Tool 'adjustment' also looks imminent... SKIP https://www.defender2.net/forum/topic83242.html |
