Home > Maintenance & Modifications > Paint blasted off wheels
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I blasted of the Landrover cream paint when pressure washing my defender wheels at a garage. There seems to be a dark blue paint underneath. Should I get the wheels re-spayed, I popped in to a powder coating shop but they only do a limited range of colours, is this normal. Has anyone else had this problem?
Post #544881 30th Jun 2016 5:58pm
leeds
Whether you decide on paint or powder coat then preparation is the key.
Our local powder coaters can do any RAL colour, price is about £45-50 per wheel and special effects are about £5-10 extra per wheel.
There are powder coaters and then there are good powder coaters. I know one firm I will use locally and a couple of local powder coating firms I will not use.
Brendan
Post #544900 30th Jun 2016 7:09pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Sadly it's normal for a defender, whether it should be the case or not...
Steel wheels on mine did the same, only lasted till they were a year old, paint started to fall off in sheets and they were rusting too. swapped them for alloys since it's not a working vehicle and they suit it better.
Post #544945 30th Jun 2016 9:04pm
Crofter
Thanks I will ask around see if I can find a powder coater to do the wheels.
I did think about alloy wheels but am put off as I had alloys on a discovery, which always seemed to suffer
from tyres loosing air when the vehicle got older. However I did keep the discovery over 10 years.
Post #544983 1st Jul 2016 5:36am
leeds
Have noticed tyres slowly losing pressure on old wheels and tyres combinations.
Could not decide if it was a case of corrosion just inside the tyre bead just forcing bead open allowing air out slowly, or if it was a case of the tyre rubber age hardening not being as flexible.
Had a set of old tyres about 55-8 years old which was prone to loosing pressure/ punctures. Replaced tyres and problems disappeared.
So in my mind a good reason to retire old tyres..
Brendan
Post #545012 1st Jul 2016 7:47am
