![]() | Home > Maintenance & Modifications > Genuine Spec "Nuts n Bolts |
All you need to know is in below thread.
![]() Eric http://www.defender2.net/forum/topic38216....mild+steel You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2706 ![]() ![]() |
Land Rover perhaps? ![]() |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 601 ![]() ![]() ![]() |
Indeed, but having experienced main dealer prices (how much for a rubber block), and seeing scores of stainless kits online, just wondered was there a source for a full kit of original spec bolts. now breath in from all that whistling
Andrew*Debbie Member Since: 25 May 2016 Location: Anglesey Posts: 95 ![]() ![]() |
I bought some inexpensive bolts from John Craddock when we first got the 110 but decided not to use them.
Britpart "OEM" door bolts look correct and are less expensive than genuine LR bolts. Quality vs Genuine Land Rover?? I have no idea. ![]() Click image to enlarge These generic ones are different. Finish looks like zinc dichromate plating. They look better to the eye then in the photo and could well stand up better than the OEM parts. They came in a clear plastic bag, so I don't know what brand they are, if any. Probably best not to use John Craddock if you want OE look parts as they don't specify a vendor. ![]() Click image to enlarge |
