Home > Puma (Tdci) > Split Second Engine Cut Off with Dash Lights
HardCharger
Hi All!
I've recently encountered this little hiccup. When cruising along or sometimes idling, the engine feels like you did mix the clutch right to accelerate and the engine "dies" for a split second then is on again. When it comes back on, the glow plug light, oil pressure light, and sometimes the battery light is on for a second or two before everything returns to normal. It was scary at first, especially on the highway at highway speeds but not it's kinda annoying and I feel that I should nip this in the bud before it will eventually get worse. Anybody experience this or know what's going on?
Thanks.
Post #544060 28th Jun 2016 1:23am
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
it sounds like a earth issue I suggest you check the earth straps
Post #544069 28th Jun 2016 5:32am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
is it a td5? if so watch the water gauge too. if it shoots to the top it's a bad connection on the main relay 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #544078 28th Jun 2016 6:58am
Check that the relays under the driver's seat are really tight in their sockets. This, and starting problems, can be caused by poor connections to these.
Post #544089 28th Jun 2016 8:24am
HardCharger
Hi andydef90,
Where do I find the earth straps? I've been meaning to check them but I don't know where to find them. Tried researching on here but I haven't had much luck finding the info.
Post #544122 28th Jun 2016 10:33am
HardCharger
Hi gasman,
It's a 2011 Puma.
Post #544123 28th Jun 2016 10:34am
HardCharger
Hi blackwolf,
This is something I haven't done yet but I did check them a week or two ago when I was having some issues with my electronics. Time to check them again, I guess. Will advise if it helped any.
Thanks!
Post #544124 28th Jun 2016 10:36am
HardCharger
Hi All!
Just an update, check all the relays - all good. The truck had to go get some body work done and had the earth points checked. After pick up, the truck was cured so I guess it was the earth points like andydef90 said.
Changed oil and all filters just to be sure.
Post #552986 2nd Aug 2016 6:01am
HardCharger
Looks like I spoke too soon and jinxed myself. Sad
It happened at least thrice last night. Big Cry
Anyone have any other ideas?
Post #553290 3rd Aug 2016 1:46am
Partyranger
South Africa 2009 Defender 90 Puma 2.4 CSW Tonga Green
Also check the terminals on the battery itself.
I had an issue recently where I also thought it's an earth issue.
Checked everywhere and even though the Negative terminal seemed tight it wasn't really.
After tightening it properly with a spanner my problems were sorted.
Also make sure the battery cannot move inside the box, I've also had it where, due to corregations, the battery positive touched the side of the box and then also caused the engine to cut out.
Post #553318 3rd Aug 2016 6:56am
dorsetsmith
HardCharger wrote:
Hi andydef90,
main one from battery follow out battery box to chassis next to transfer box
chassis to body work right hand side at the bulk head flat brad between chassis and body
Post #553326 3rd Aug 2016 7:26am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hah a similar issue on a 2013 2.2, it turned out to be loose connections on the back of the ignition barrel.
A quick fix with a dob of solder Very Happy
Post #553331 3rd Aug 2016 7:54am
HardCharger
Thanks for the clues and tips! Thumbs Up
Will look into them and come back to report the result and hopefully not jinxing myself anymore. Mr. Green
Post #554382 8th Aug 2016 3:12am
HardCharger
Hi All!
Just a little update:
The ignition switch is properly plugged. So far,, all the earth points seem secured and connected. Recently had work done on the AC compressor as it stopped working due to a dead magnetic coil and it needed new bearing but a little bit of machine work on the pulley. While leaving it to run, it was noticed that the hiccup, when it does occur, coincides with the compressor kicking in. The hiccup is very pronounced now. While I think the compressor thing is kind of a coincidence, as the hiccup does happen when the AC is off, does this little bit of info help narrow down the problem and how to fix it? Question
Post #560415 1st Sep 2016 2:56am
Caterham
D you check the battery terminals. Not just tight bolts but actually tight on battery?
Good luck.
Post #560450 1st Sep 2016 7:55am
