![]() | Home > In Car Electronics > The Alpine bluetooth headunit, and the RCA out on the back |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1440 ![]() ![]() ![]() |
Hi,
I have the factory option sub, so haven't tried connecting a full range amp, but have played around with the high & low pass filters on the speakers and sub. There may be a LPF "off" setting on the line out, somewhere in the settings menu. In that case it would give full range. I can't remember just now. How are you wiring up the other 4 channels, speaker level inputs? -or do you plan to split the single line out to give F, R and SUB? cheers. |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 ![]() ![]() ![]() |
Ideally you need a 3 pre outs from the headunit which would be front/rear and sub. You could use splitters to get 3 pre outs but the standard unit IIRC only give 4 volts splitting it twice would see a real drop in performance and crap sound. You also would have no control, as in fader front/rear. The red and white pre outs are stereo though
^ Agree with Jim, a head unit with 3 pairs of outputs would be a better solution for a 6 channel amp.
Regarding the 2 RCA's on the factory Alpine unit marked F/SUB, they will output stereo FRONT full range or SUB depending on the setting. In the settings, Subwoofer OFF, is the setting for the Front signal. Presumably that can be faded front to rear on the head unit. Subwoofer ON, sends a SUB signal, which I think is not faded, but the LEVEL can be set independently. SUBW LPF has settings for OFF, 60Hz, 80Hz, 120Hz, 160Hz. Set to OFF (ie no filter) you should again get the full range through the 2 connections. Hope that helps. |
Replace it with the alpine cde-178bt it's much better
![]() My build thread http://www.defender2.net/forum/topic17615.html |
