![]() | Home > Puma (Tdci) > SVX front lights |
the dealer should have left the SVX fitting instructions with you.
SVX headlamps are still H4 the indicator lamps are the same but may have orange coating the side lights are different the AUX lamps are H9s there is an electrical supplement manual for the SVX front end and LED rear lights.... someone on the forum should be able to email it to you. as for changing bulbs - probably have to remove the front plinths to get to the light units. BTW- Hella are introducing 90mm spot light LED units - I'm going to replace the standard LR units with these when I can find them. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Thanks for the feedback BPman. I'll contact my dealer and find out if they still have the paperwork for the SVX front which would be really useful. In the mean time if there is anyone out there who could mail it to me that would be much appreciated. I certainly didn't get it when I collected the vehicle.
When you say that Hella are introducing some LED replacements for the standard LR ones, do you mean the standard Hella SVX front ones? If so, I'd be interested in those, although I think the existing ones may be difficult to improve upon. One of the main reasons I went for the SVX front was the massive improvement in lighting over the standard vehicle. The Hella lamps do make a lot of difference. ![]() |
Pete
there was an advert in LRO a month ago ... http://www.hella.com/produktion/HellaSG/We...032_en.pdf is all I can find at the moment .. still looking |
