Home > Maintenance & Modifications > Fridge location
Page 2 of 2 <12
Vixen
Australia
Permanent fixture. Small section rear seat removed. Makes it high though so a short person needs a little stool
You can see more here http://landytown.myfastforum.org/about4339.html but you will have to sign up on the forum to view it
Post #54285 21st Jan 2011 8:23am
jst
my passenger seat can go all the way back on the runners but not 'recline' all the way and still let you open the fridge. it depends on the size of your codriver and how they like to sit i suppose. have certainly had no problem in the past. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #54289 21st Jan 2011 8:39am
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
This is all great stuff! At last somebody else that understands what I'm trying to achieve.
Ideally, I'd want whatever shelf solution to pick up on existing bolts (to reduce drilling as much as possible) and for the seat to be replaced in the winter months (ferrying half a kids rugby team around and less need for 'cold' beers!).
Re the Sonic solution, I'm pretty sure the length of the MT45 is greater than the width of the removed seat or does it slide in over the top of some of the middle seat I wonder? I guess I could ask him!!
Cheers all so far.
Post #54319 21st Jan 2011 10:17am
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
AndrewS wrote:
Is the fridge mount going to be permanent?
Do you need the 40 split 2nd row seat? If not remove the seat make a platform for the fridge.
Yellow is a platform, pink is the fridge blue is a hand cubby box under the fridge ideal for ropes straps etc
Thats exactly how mine is mounted.
I removed the $0 seat, and behind it on the wheel arch there is a lip (TD5) The rear of the table fits onto the lip, the from is supported by 2 legs which go down to the floor.
You could then mount the engle fridge plate to the table, but I have used ratchet straps sucessfully.
I will try to get some photo's tomorrow. 2002 Defender 110 DC
Post #54365 21st Jan 2011 1:46pm
TACK
Andy, did you get round to taking any photos buddy Question Thumbs Up
Post #57576 7th Feb 2011 9:44pm
JSG
Cheers all so far.
Ade, Si has his fridge in place of one of the rear seats on his 110 so it should fit ok. Thumbs Up John
2011 Tdci 110 CSW XS
Post #57599 7th Feb 2011 11:27pm
TACK
Had ago at the fridge Mount today, Basically ply and 3x2. Took longer than expected as I wanted it to sit as low as possible without causing an issue with the front passenger seat. Last picture shows the seat in its furthest position and with a fair bit of recline.
Drilled no holes in the body work, where the seat normally rests on an angled plate with a little rubber pad on top of it, under the rubber pad is a hole, I used that to fix into, thus the shiny top of a coach bolt you can see in the pictures, I also used the existing horizontal fixing holes which hole the seat in place, the existing bolts were to short to go through the ply and into the body work, so slightly smaller diameter but longer bolts, through the hole and then a nut on the end of this which is accesable from under the wheel arch.
Sits flat and fairly strong. My fame of mine is making sure it would be strong enough in an accident, although I do not know how it will be or indded intend to find out, I always think of this and try to use the best fixings possible.
Going to remove the handles from the fridge, and use tie down bolts to the front and fix the rear of the fridge to the load guard.
I am going to carpet the ply and timber, would a normal carpet place do something suitable? I may cut the ply back a bit (flush to the edge of the fridge) but thinking this is also a good and maybe safe place to secure a fire exinguister
Post #57791 8th Feb 2011 7:59pm
Vixen
Australia
Now...that's all looking familiar Very Happy
Just a thought on removing the handles.....it's pretty awkward getting the fridge into the vehicle as you've no doubt found out. Will you be able to do it easily without the handles? I never access the fridge rom inside the vehicle while travelling, so used to run a strap over the fridge and down under the platform it sits on...as long as that is well secure, it should hold the fridge secure enough in a roll over, and stop the fridge jumping out of it's seating holes on rough roads.
Post #57910 9th Feb 2011 7:37am
leeds
If removing the handle replace with a light weight lashing eye. It will lay flat. Just thread ratchet strap webbing through it.
Fridge 'permanently' lashed down so no forgetting ratchet strap over the top to 'forget' when moving off.
When things go wrong they go wrong very fast! All hard objects in passenger compartment should be firmly secured down
Brendan
Post #57912 9th Feb 2011 7:51am
Vixen
Australia
Brendan
So true...I was always banging on about that to my ex. He didn't quite see things the same way as me. Luckily we never found out just what a mess flying objects can make of you.
Post #58216 10th Feb 2011 9:34am
18stone
Well, nearly 2 months on and the solution is in place.
It's secured via rivnuts through the store drawer and wheel arch. The front has a leg which extends through the seat bracket and is secured by an R clip. The rear leg is free standing. It's as solid as a rock and easily removed. The Engel slide-lock is screwed to the tray top. Very pleased with the result.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  D300 HSE 110
Post #66262 5th Apr 2011 11:23am
TACK
Never did post a pic after i had finished the fridge install. have now Thumbs Up
Post #78866 3rd Jul 2011 9:31pm
Page 2 of 2 <12
