![]() | Home > In Car Electronics > Interior Light (Rear) |
How much current do you need? You can use the interior light circuit or the towing electrics providing you don't overload anything
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
I dont have the owing electrics (annoyingly otherwise i would take a live feed)
4 amps is what i want to take I assume its the purple brown - unless there is another +ve feed in the rear? Mike |
Thanks BTW
Even though you haven't got a tow bar/trailer socket fitted haven't you still got the multi-plug tucked away behind the lights on the off side rear? The plug to join the plug and play towing electrics along with a positive feed.
Thanks - thats what i did, i dont like hacking into looms - so ive put a temp feed up to power a few things which i can now do.
Rather annoyingly broke the clip holding the plug on ![]() |
