Home > Puma (Tdci) > Center dash lights fuse?
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
Is there a fuse for the lights behind the heater controls. A couple of mine had gone so removed the duff ones but now none work. I wonder if I have blown a fuse by removing one as I broke it getting it out. Oh, and they aren't 501 bulbs as mentioned in another post they are much smaller. So now I have a glut of 501's I bought in antisipation of replacing.
As a side note, the clock and hazard switch still light up...
Post #542412 22nd Jun 2016 2:39pm
No separate fuse, as I recall, but it can be a right pain getting the bulb to seat correctly in the holder. There is also a connector between the heater control lights sub harness and the main dash light harness, if this is dislodged you'll have no heater lights.
You may also find that those bulbs can overheat when failing and damage the uber-expensive heater control panel. Big Cry Ask me how I know!
Post #542421 22nd Jun 2016 3:05pm
spudfan
Ireland
O.K. then tell us "HOW DO YOU KNOW?" Rolling with laughter Rolling with laughter
Seriously though, sorry for your misfortune. These things can be a pain in the neck Thumbs Up 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #542441 22nd Jun 2016 3:58pm
Pinky
All sorted! They all just needed a gentle push right home, now all four working.
The Lucas part number is LLB286, they are 1.2w capless bulbs on a 2011 puma, not the 501 capless as metioned somewhere else on the forum.
Post #542465 22nd Jun 2016 5:35pm
I know because one cold wet night I couldn't turn the b****y fan off speed 3 after demisting! The bulb for the fan switch had melted the backside of the panel to such an extent that the slider was stuck.
That panel is something like £500 too, it went up from around £80 about a month before I needed one. Big Cry
In the end I reshaped mine and it has been ok since, though intentionally I have left that bulb out.
Post #542476 22nd Jun 2016 6:06pm
spudfan
Ireland
Post #542481 22nd Jun 2016 6:12pm
